Is it possible to bypass the ignition with push start?
4,688,633 MILES
DECOTA DWIGHT
Someone tried to steal it and broke the ignition switch.
Oct 31, 2022 at 8:40 AM
  • 110,248 POSTS
Anything is possible, but in this case, it wouldn't be easy. Everything as far as the electronics on this vehicle is designed to function using a key. Antitheft will be the biggest obstacle along with the need to replace sensors and possibly the body control module.
I have just tried to help someone with a Chrysler product with the same issue and plan for repair. He has been into it for two weeks and it still won't start. I would consider just replacing the ignition switch lock cylinder and the switch itself if damaged.
Oct 31, 2022 at 12:09 PM
