Possible fuel problems
124,000 MILES • 2.5L • 6 CYL • 2WD • MANUAL
JAMIL ABU SALEH
Hello, I have the vehicle listed above, GTST with a rb25det engine. I currently am having a problem where the car will cut out (as if fuel stops delivery ) when full throttle, however if I build up to the boost and accelerate slowly no issues at all. Also, the car sometimes idles very low and almost stalls to the point where the battery indicator on the cluster instrument will light up for a split-second. Last thing is the car needs some throttle when starting up otherwise it will start and shut off instantly.
it seems as if there is not enough fuel supply or perhaps an injector problem? This is just my guess. Will appreciate feedback.
May 25, 2018 at 12:01 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
All three of these problems sound like it could be either loose connection to or a failing throttle position sensor.
May 25, 2018 at 2:01 AM
  • 55,604 POSTS
This sounds like one of two things to me first check the end play on the turbo to see if it is excessive.
https://www.2carpros.com/articles/how-turbo-chargers-work
Next I would remove the IAC valve and service it. Here is a guide:
Please let us know what you find.
Cheers, Ken
May 25, 2018 at 5:00 AM
