1984 Other Porsche Models 1984 944 Stereo Electrical Issue
1984 PORSCHE
70,093 MILES • 4 CYL • 2WD • MANUAL
TREKINOUS
  • 28 POSTS
The stereo won't get any power. I checked the wires and they have no power going to them. The stereo, clock, interior light and cig lighter are all wound into the same circuit. And the fuse is good. What else could be the problem? The fuse box itself?
Oct 9, 2008 at 2:08 PM
DOC762399
  • 8 POSTS
SO is it that you have no power to any of those things on the same fuse or just the stereo? If it is to that fuse , then check to make sure the two contact points the fuse inserts into, are in there factory position. These fuses will push the contacts down to the point they will not make contact. If it is just to the stereo? i would check to see if the fuse on the stereo is bad. No power to the wires that feed the stereo? goes to the fuse box.
Oct 20, 2008 at 11:43 PM
