1999 Porsche Boxster
LJS123
  • 1999 PORSCHE BOXSTER
1999 Porsche Boxster 6 cyl Two Wheel Drive Manual
My engine light came on, so I took the car to the local auto parts store. They hooked it up to a computer. The computer states that the MAF has failed, and could be caused by high fuel pressure, canister purge solenoid stuck open, or failed H02s in banks 1 @ 2. Please help!
Thanks,
Larry
Wednesday, September 29th, 2010 AT 4:27 PM
CWPORSCHE
  • 58 POSTS
Fuel pressure has nothing to do with a failed maf sensor and oxygen sensors don't likely all fail at the same time. Not knowing what the fault code is and tra values and based on your description and history of failed maf sensors, i'm betting your air mass sensor or (maf) has failed.
Wednesday, October 6th, 2010 AT 8:30 PM
