2004 Pontiac Vibe clutch repair
2004 PONTIAC VIBE
101,000 MILES • 4 CYL • FWD • MANUAL
KMCT90
I think I need a new clutch on my 2004 vibe GT. could you give me an idea of the cost. I've called around locally and had price range from 750 to 1300. Also is ther a better clutch to have put in to handle the higher torque of the GT?
Thanks for your help.
Jan 26, 2010 at 6:20 AM
BRIAN 1
  • 1,030 POSTS
your looking at about 6.5 hrs labor and $171.00 for the clutch.about $800-$900 is about wright.you could call a local parts store for a better clutch,dont know which store there all about the same.
Jan 26, 2010 at 8:49 AM
KMCT90
in your opinion do you think a beefier clutch would last longer, and if so what would i need to ask for at the parts store?
thanks again for the help
Jan 27, 2010 at 2:33 AM
BRIAN 1
  • 1,030 POSTS
its kinda hard to say if it will last longer,it depends on how you drive,it should last longer if its a heavy duty clutch.I would ask for a more heavy duty clutch,one that will stand up to more punishment that might be a better option than OEM.
Jan 27, 2010 at 3:14 AM
