2003 Pontiac Vibe Noise in Dash?
2003 PONTIAC VIBE
12,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHESSIEMAN
There is a pulsing noise that is in tune with the air blower. Sounds like it's on right side of dash under passenger air bag. Clicking type noise - thought at first something got down the vent hole and was making noise, sounds like an electrical problem? but just the noise - has not effected driving or functions?
Thanks.
Jun 28, 2010 at 1:29 AM
MMPRINCE4000
  • 8,548 POSTS
Could be the blower motor, does it only do it with motor on?
There are vacuum switching valves near TB that will click and sound like a lifter.
Jun 28, 2010 at 1:57 AM
CHESSIEMAN
Yes it is when motor running, but also does it with fan OFF as well ??
Jun 28, 2010 at 6:56 AM
MMPRINCE4000
  • 8,548 POSTS
As I said there is a vacuum switching valve near TB that will click, and sounds like a lifter.
They are about $68 from Toyota.
Jun 30, 2010 at 1:34 AM
WINGS67
I had the same issue with my 2005 Vibe. The noise is caused by the servo mechanism that opens/closes the ventilation door (fresh air mode/recirculate air mode). One of the gears inside the mechanism is stripped, which is causing it to slip.
Good news is you can fix this yourself. Just remove the glove compartment door, reach in with a very small ratchet and 5.5mm socket; there are 2 screws to remove.
Aug 8, 2010 at 4:02 AM
