1975 Pontiac Ventura front springs
1975 PONTIAC VENTURA
10,000 MILES • V8 • 2WD • AUTOMATIC
BUCKWOMAN1982
how can I find a good repair shop to replace the front springs which are shot? It bottoms out on the littlest bump. The shocks I can replace myself.
Is there a specific type of auto repair I should look for?
Apr 29, 2009 at 5:28 PM
ADAM PRZYBYSZEWSKI
It's easy to replace you're front springs you'reself if you live in Canada you can go to Canadian Tire go to the parts Dept. ask them for a coilspring compresser all it will cost you is a downpayment of say 20-30 dollars and when you bring the tool back you get every cent back . That way it saves you a couple hundred dollars and it is also done safley but if you don't want to do it then the best thing to do is shop around at any garage , you don't need a place that is suppose to speciallise in doing front springs it will cost you twice as much to do the same job . Adam Przybyszewski (polski) (;
Jun 12, 2009 at 6:53 AM
