Serious problem...
ABHKIP
I recently aquired a 1997 Pontiac Sunfire 2.2L which will start (sputters), but smokes (white) really bad, lacks power and/or dies when you step on the gas. The old owner had work done on it - new fuel pump, cleaned injectors, cleaned gas tank and new cat. converter. Before I get started I'd like a word from the pros, I'm thinking head gasket or timing? Any suggestions?
Jul 8, 2006 at 10:54 AM
HEADHUNTER
  • 22 POSTS
i would have to say head gasket, check and make sure the oil is the color it's supposed to be.
Jul 8, 2006 at 11:39 AM
PONTIACDAN
  • 13 POSTS
Yup sounds like head gasket to me. Check all around the head especially the two front corners for dampness that might indicate leaking coolant.
I have 270,000km on mine and just replaced the head gasket. Apparently it is common with these engines sooner.
Jul 31, 2006 at 6:12 AM
