1997 Pontiac Sunfire Surging Then Dies
WODEN
97 Pontiac Sunfire 2.4 w/ ~150,000km
Day before noticed idle slightly rising then droping while at a stop. Next day ran fine, then suddenly lost all power and died while on highway. Towed car home, after sitting for 8hrs car started right up but surges excessively when in park, in drive car lunges rythmatically and after minutes it stalls and becomes difficult to start. Temperature last couple of days dropped to -14 deg C, no Codes, any idea?
Thanks
Feb 5, 2007 at 2:26 PM
2CARPRO JACK
  • 11,533 POSTS
The smaller GM cars around those years had some issues with the catyletic converters plugging.Loosen the exhaust pipe at the manifold and start the car.It will be loud but that lets the exhaust out without going through the converter.Drive it a little and see if it has normal power. Let me know how it goes
Feb 6, 2007 at 11:42 PM
WODEN
I completely disconnected the exhaust pipe going to the manifold and this did not change the condition.
Feb 8, 2007 at 2:28 AM
2CARPRO JACK
  • 11,533 POSTS
Check the fuel pressure. Has the car been tuned up? the coil housing on that engine should be replaced during a major tune. Also check for vacuum leaks
Feb 9, 2007 at 1:31 AM
Suggested Repair
A disconnected exhaust test ruled out a plugged catalytic converter. Check fuel pressure and vacuum leaks, and replace the coil housing as part of a tune-up.
Conversation Summary
A 1997 Pontiac Sunfire 2.4 with about 150,000 km developed a rising and falling idle, then lost power and died on the highway. After sitting, it started but surged in park, lunged rhythmically in drive, stalled, and became hard to start in cold weather with no codes. Disconnecting the exhaust at the manifold did not change the condition. The expert then advised checking fuel pressure and vacuum leaks and replacing the coil housing during a tune-up.
