I got a diagnostics code p130 oxygen sensor failure
so i replaced the upstream sensor with a Bosch part 13191 oem type. come to find out the new sensor has 2 wires (1 black, 1 gray). My old sensor has 4 wires (2 white, 1 black, and 1 gray). Can i just use the 2 wires that came with the new sensor or DO I HAVE TO SPLICE THEM AND MAKE 4 WIRES OUT 2, so i can insert it into 4 slot connection? What i did was i just used the 2 wires wires for the connection and now i have 2 empty connection slots. Is this right or did i make and error? Oh, and after i replaced the sensor the "trac off" light lit up on the dash.
May 5, 2007 at 8:27 PM
