2000 Pontiac Sunfire Repairs for odb2 code P0202
2000 PONTIAC SUNFIRE
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
TROHM
Check engine light keeps coming on with the odb2 code of P0202.
What needs to be done to repair it?
Mar 13, 2010 at 6:03 AM
MERLIN2021
  • 17,250 POSTS
P0202= injector circuit cylinder #2, either the injector or the wires to it arent working. See if when it's running the injector clicks, put a finger on it you should feel it. Then use a test light or volt meter or noid light and check for voltage that pulsates.
Mar 13, 2010 at 6:23 AM
