2000 Pontiac Sunfire
SMILI
  • 2000 PONTIAC SUNFIRE
Air Conditioning problem
2000 Pontiac Sunfire 76000 miles
My A/C isn't cold, but when I put more refrigerant in it, then it is cold again. I just don't know how much refrigerant to put in and I can't seem to locate the answer anywhere else. How much do I put in?Thanks!
Tuesday, March 11th, 2008 AT 6:04 PM
MASTERTECHTIM
  • 4,750 POSTS
Most likely you have a leak in the system somewhere. There is a refrigerent dye you can install in system and then look for the colored dye and repair as necessary
Tuesday, March 11th, 2008 AT 6:21 PM
SERVICE WRITER
  • 9,123 POSTS
21.6 ounces is the full recharge. The system should be completley evacuated before a full charge is put in. But like Tim says, you need to locate the leak.
Tuesday, March 11th, 2008 AT 6:45 PM
