HOW HARD IS IT TO CHANGE OUT THE WATER PUMP ON THIS CAR?
Friday, July 17th, 2009 AT 11:38 AM
BLUELIGHTNIN6
MECHANIC
Not too bad of a job. Disconnect negative battery cable. Drain coolant. Loosen the water pump pulley bolts. Remove the drive belt. Remove pump pulley and surge tank hose. Remove water pump gasket.
