1999 Pontiac Sunfire Sunfire engine swap
1999 PONTIAC SUNFIRE
144,000 MILES • 4 CYL • FWD • AUTOMATIC
CAMMAN27
I have a 1999 Pontiac Sunfire and the crankbearings are shot. I was looking at buying a used engine from a 1998 Sunfire. Would this engine swap out perfectly? Also the engine i'm looking at buying has a cracked fly wheel so i was wondering if the one from my car would fit on the 89 engine?
Mar 7, 2010 at 12:52 PM
HMAC300
  • 48,601 POSTS
it should work as long as they are the same like 2.2L and not one engine 2.2.L and the other a 2.4L or 2.0L. That's where you run into problems. You can pick up a crank kit for abut $500 or less though if you just want to keep your engine .
Mar 13, 2010 at 1:13 AM
