1999 Pontiac Sunfire Engine Stopped, won't start
THUMBZ
  • 1999 PONTIAC SUNFIRE
  • 4 CYL
  • FWD
  • 194,000 MILES
Ok, so I was on the auto part store to get parts to fix my car. I had a leaking coolant rail when my engine stopped running. The temp gauge didn't overheat. It took me 45 minutes to pull spark plugs, they are in need of replacing. Any other suggestions to check?
Saturday, July 10th, 2010 AT 3:45 PM
MMPRINCE4000
  • 8,548 POSTS
Have ignition module tested.
Tuesday, July 20th, 2010 AT 8:46 AM
THUMBZ
Where can I get the module tested? The coils, plugs, and plug wires all checked out. Timing is correct.
Tuesday, July 20th, 2010 AT 12:57 PM
MMPRINCE4000
  • 8,548 POSTS
Most autoparts stores test modules.
Wednesday, July 21st, 2010 AT 7:03 AM
THUMBZ
Ignition module tested out good. Plugs changed. Coils and wires tested out correctly on ohm meter. Timing is on. I believe I am hearing my fuel pump still kick in.
Tuesday, July 27th, 2010 AT 9:56 AM
MMPRINCE4000
  • 8,548 POSTS
Next step is to check fuel pressure.
Wednesday, July 28th, 2010 AT 8:15 AM
