HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Sunfire
Engine Cooling
Water Pump
1998 Pontiac Sunfire water pump
KINGER_29
MEMBER
1998 PONTIAC SUNFIRE
1998 Pontiac Sunfire 4 cyl Two Wheel Drive Automatic
how do I repair a awter pump on a 98 sunfire gt
Tuesday, July 21st, 2009 AT 5:26 PM
BLUELIGHTNIN6
MECHANIC
SPONSORED LINKS
Tuesday, July 21st, 2009 AT 9:03 PM
Please
login
or
register
to post a reply.
Related Water Pump Content
1996 Pontiac Sunfire Water Pump
I Need To Know How The Water Pump Come Out So I Can Put The New One In Please Help Me With This So I Can Drive My Car Again.
Asked by
t_kimber
1 ANSWER
1996
PONTIAC SUNFIRE
GUIDE
Water Pump Symptoms
The water pump is designed with a weep hole to allow coolant to leak from its housing before it can reach the shaft bearing which will cause the shaft to lock up and stop...
2000 Pontiac Sunfire Green Fluid From Water Pump
Engine Cooling Problem 2000 Pontiac Sunfire 4 Cyl Front Wheel Drive Automatic There Is A Green Fluid Around The Water Pump. The...
Asked by
blueolds
1 ANSWER
2000
PONTIAC SUNFIRE
1998 Pontiac Sunfire Overheating, Needs Thermostat...
I Was Told That I Needed To Try To Change My Thermostat In My 98 Sunfire. I Am Completely Clueless As To How To Do It. I Have Never Tried...
Asked by
Femaleneedshelp!
1 ANSWER
1998
PONTIAC SUNFIRE
Engine Cooling Problem 1998 Pontiac Sunfire 4 Cyl Front Wheel Drive Automatic 100k+ Miles Hello- I'm Praying You Can Assist Me! Check...
Asked by
callievega
1998
PONTIAC SUNFIRE
1998 Pontiac Sunfire Need Advice In A Bad Way!
My Car Is Getting Hot When At Idle Like Stopping At A Red Light And Especially When Under A Load Such As Going Up A Hill. I Have Tested The...
Asked by
Ziprhead
1 ANSWER
1998
PONTIAC SUNFIRE
VIEW MORE
SPONSORED LINKS
Water Pump Replacement
Water Pump
Online car repair manuals
