1997 Pontiac Sunfire cuts out while cruisng
JOESHOVZ
  • 1997 PONTIAC SUNFIRE
  • 4 CYL
  • FWD
  • MANUAL
  • 100,000 MILES
My 1997 sunfire seems to cut uot while cruising at around 2000-3000 rpm. Btu it seems to stop when I give it gas. Seems like fuel restriction but then it should studder when I step on it, right. Anyone who can help please do. Thanks
Tuesday, November 25th, 2008 AT 7:50 PM
JON GAUDET
I had that problem with my 2000 sunfire and try a new battery because the sides of the battery were puffed out the coil pack needs 12 volts constantly so if u have a bad battery or alternator it will cause this problem hope this helps let me know
Saturday, December 6th, 2008 AT 12:57 AM
JOESHOVZ
Thanks for your reply, I found that changeing the coil packs solved the prob.
Saturday, December 6th, 2008 AT 10:35 AM
