1996 Pontiac Sunfire stalling
MEBMAN
  • 1996 PONTIAC SUNFIRE
Engine Performance problem
1996 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
1996 Pontiac Sunfire 2.2 stalls while driving, daytime headlights go out, as if the car is being turned off. However, after 2-5 minutes the car will restart and run.I have also noticed the the "check oil" light is on, even though the oil level is full.
Thursday, September 3rd, 2009 AT 5:14 PM
  • 109,772 POSTS
First, if the oil light is on, are you hearing any knocking or ticking from the engine? If not, replace the oil sending unit. If the computer thinks you have no oil pressure, it will shut the engine down. THe sending unit is most likely the problem.
Let me know if this helps. NOTE: It isn't an expensive part, easy to replace, and is located near the oil filter.
Monday, September 7th, 2009 AT 10:55 PM
