1994 Pontiac Sunbird AC Noise
ANDRBROW
1994 Pontiac Sunbird 2.0 with 160,000 kms.
My car is making a funny sound that seems to be related directly to the amount of gas that you give the car; Rev it and it increases, etc. Needless to say, it sounds terrible. I was told that it is some part of the AC system that is causing this noise regardless of if the ac is actually turned on from the dash. Question is if I can just disengage this so it does not get any power and therefore not cause the noise? I understand that I could lose the use of my AC but considering I only would be tempted to us it for a whole two months (life in Canada), I don’t think it is really worth the $$ to replace. So is it possible to run the car without the AC or is it attached to something else that I’m not aware of?
Apr 20, 2006 at 1:56 AM
LOSONE
  • 1,616 POSTS
Take off the belts one at a time and start the car for a few seconds. You can tell when the problem goes away. The A/C bearing, the idler pully or a water pump could be the culpret. Let me know
Apr 20, 2006 at 2:05 AM
Suggested Repair
Remove the belts one at a time and briefly start the engine to isolate the noise. Check the A/C compressor bearing, idler pulley, and water pump.
Conversation Summary
The owner of a 1994 Pontiac Sunbird 2.0 reports a noise that increases with engine speed and was told it may come from the A/C system even when the A/C is off. They asked whether the A/C could simply be disengaged. The expert advised removing the belts one at a time and briefly starting the car to identify the source, which could be the A/C bearing, idler pulley, or water pump.
