[quote:14b1f73692="kin chan"]any slowing down of heat transfer could cause overheat.....typically long distant hwy driving over heating cause highest failure cpt is radiator clogging up.......thermostat which stick in close position usually will act up over heating within 10 minutes in driving......[/quote:14b1f73692]
Or try all the following below:
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
_________________
Am not looking down and there's noone above me-
Jul 27, 2007 at 8:03 PM
