abs brakes
PONTIAC SUNBIRD
FROGGYDAN59
hi i have a93 sunbird aprox 350kkm yesterday when leaving work the brake pedal went slowly to the floor brakes still worked, barely, i changed the master cyl and bled the air from the system but still have no pedal the manual i have for the car has no info on the abs control could it be causing the problem?
thanks for any help.
Jan 23, 2007 at 8:29 AM
1934FORD
  • 6 POSTS
[quote:3c430cf4b3="froggydan59"]hi i have a93 sunbird aprox 350kkm yesterday when leaving work the brake pedal went slowly to the floor brakes still worked, barely, i changed the master cyl and bled the air from the system but still have no pedal the manual i have for the car has no info on the abs control could it be causing the problem?
thanks for any help.[/quote:3c430cf4b3]
How did you bleed the brakes? Was someone pumping the brake pedal when you were loosing the bleeders. You need to start bleeding in a sequence starting at the right rear, left rear, right front, and the left front. make sure you check the fluid in the master cylinder to make sure you dont run out of fluid.
Jul 20, 2007 at 11:50 AM
