1994 Pontiac Sunbird steering
HARWOOD
1994 Pontiac Sunbird 4 cyl Two Wheel Drive Automatic
heard a snap when i was backing up, went forward fine and driving was fine, went to turn a corner and the steering wheel didnt want to turn
May 13, 2009 at 1:32 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely a CV shaft or wheel bearing.
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
May 13, 2009 at 2:38 AM
