1991 Pontiac Sunbird car wont star even after new starter
1991 PONTIAC SUNBIRD
COLLEGEBALLPLAYER14
Engine Mechanical problem
1991 Pontiac Sunbird 4 cyl Automatic 130000 miles
Hi I have potiac sunbird 1991 4 cylinder and I changes the starter on the car and it started up after 4 hours of driving i went to the gas station and when I tried to start my car again and it wouldn't start it just made a clicking noise what could it be???
Aug 8, 2008 at 1:35 PM
VALCALDERA
  • 8 POSTS
WHERE did you acquire the Starter: Auto Zone, Advance Auto, Pep Boys or some other cheap Auto parts dealer?
Some of these new or "remanuf(r)actured" starters are not that well redone. Some come with faulty Solenoids (the part that engages the starter gear onto the Flywheel). Sometimes 2-3 starters are required to finally get the right one from Auto Zone, Advance Auto, Pep Boys, etc.
I generally go to NAPA as it's usually a ONE TIME visit.
Sometimes just the act of removing and replacing a Starter enables the replacement of the Battery or Alternator, so go figure.
How OLD are the Cables attached to the Battery?
There could as well be Corrosion within them and this will cause a limited/erratic amount of Voltage to the Starter.
You might need to install a Heat Shield between the Engine/Exhaust Manifold and the Starter as Heat causes Solenoids to become useless and these will only click when engaged.
Sep 14, 2008 at 6:20 AM
