1985 Pontiac Trans Am trouble code 44
1985 PONTIAC
68,000 MILES • V8 • 2WD • AUTOMATIC
SMAGINLEY
car runs fine for 5 minutes then this light comes on and i get code 44, i just put in a new ecm, ignition module, and oxygen sensor, fuel pump, fuel filter. I am getting fed up with the car please someone tell me what the solution is for this code......
Aug 19, 2008 at 8:12 PM
TEAG
  • 158 POSTS
A code 44 is an indication of a lean mixture as indicated by the oxygen sensor readings. The code 44 for lean exhaust is most likely caused by one or more of the following:
1.) O2 sensor wire - Sensor pigtail may be mispositioned and contacting the exhaust manifold.
2.) Check for an intermittent ground wire between connector and sensor.
3.) Poor ECM to engine block ground.
4.) MAF Sensor - A MAF sensor that causes the ECM to sense a lower than normanl airflow will cause the system to go lean. Disconnect the MAF sensor. If the lean condition is gone then replace the MAF sensor.
5.) Vacuum leaks can cause a lean condition and/or possibly a high idle. Check for cracked hoses a bad gasket or a faulty EGR or PCV Valve.
6.) fuel pressure - system will go lean, if pressure is too low. It may be necessary to monitor fuel pressure while driving the car at various road speeds and/or loads to confirm.
7.) Clogged injector or lean injector - perform an injector balance test.....
Hope this helps. :)
Oct 19, 2008 at 5:03 PM
