2006 Pontiac Montana Rotors
XBALX
Brakes problem
2006 Pontiac Montana 6 cyl Front Wheel Drive Automatic
How do you remove the front rotors on a 2006 pontic montana? I removed the t type screw between the lugnut studs but the rotor still would not come off. Is there some kind of trick to this?
Jul 13, 2008 at 11:33 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3e72ae8111="xbalx"]Brakes problem
How do you remove the front rotors on a 2006 pontic montana? I removed the t type screw between the lugnut studs but the rotor still would not come off. Is there some kind of trick to this?[/quote:3e72ae8111]
You may just need to tap on it with a hammer to break the rust loose. I would also spray some WD40 or similar around the center.
Jul 14, 2008 at 12:29 AM
XBALX
I already tried that. I did not work.
Jul 14, 2008 at 1:28 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, it is really rusted on there then. Spray around the studs and into the retaining screw holes, saturate well let set for a little while. Then take hammer and beat on rotor between studs to break rust bond, this may take quite a bit of beating.
Jul 14, 2008 at 7:43 AM
