2001 Pontiac Montana fans no coming on
GOODMOONDANCER
  • 2001 PONTIAC MONTANA
  • 6 CYL
  • FWD
  • 114,000 MILES
Fuses seem ok, how do I get the fans to run,
engine is over heating
how do I check mini relays
what else would stop fans from running
also ac stopped working 1 year after recharged
please email answer to goldmedalforyou@hotmail. Com
Tuesday, September 22nd, 2009 AT 4:26 PM
  • 109,885 POSTS
Run a jumper wire from the battery to the fan motor to make sure it is good. Let me know what you find
Wednesday, September 23rd, 2009 AT 10:55 AM
GOODMOONDANCER
Thank you for responding, Ill do that if I can find a wire.I did check the continuity from one lead on the motor to the other side on both motors. Meter goes back to zero. Ill try the jumper and get back.
Thank you again
Robin
Monday, September 28th, 2009 AT 5:39 PM
  • 109,885 POSTS
If the motor is good, it will run when you put voltage to it. If it doesn't turn on with the jumper, replace the motor.
Monday, September 28th, 2009 AT 9:07 PM
