Transmission problem
2000 Pontiac Montana Front Wheel Drive Automatic
my transmission all of a sudden stated jurking(i guess u could call it) into gear but it doesnt do it all the time. And when it does do it i can pull over shut my car off and then restart my car and it will drive fine. I was told that because my egr valuve code is coming on that this may cause the issue ...is this true can a egr valve cause a transmission to run differently? and if not is there something else that may do this ? again it does not happen all the time .
Jul 28, 2009 at 12:29 PM
