It's a hard question to answer with certainty, but I can tell you is its probably a hose. like most hoses they get brittle and deteriorate with age. I cant recomend driving to shop to get it fixed, but if it were mine I would only drive it a very short distance and only if leak were very minor, which its obviously not or you probably would not have noticed.
Most likely it will be a dealer only part but still generally are not real expensive, but it depends on which one it is.
You can try to locate by following trail of gas u
Jan 28, 2009 at 2:26 PM
