switch and push button ignition
JOKING91388
1988 Pontiac LeMans not sure on the mileage the cars ignition switch has been broken out and I tried to install a switch and push button to start the car. The car starts but the battery dies when left hooked up over night. I was wondering if I might have hooked the switch and push button up wrong, or if I have another problem.
Oct 10, 2006 at 8:54 PM
PJ(GTO)
  • 36 POSTS
The problem could be a few possible things, but I don't think your switch is the problem unless the switch is always left on.
But the first thing to check would be your alternator, carefully disconnect your neg. cable from battery while it is running if the engine dies within about 2-3 seconds its you alternator, if it keeps running then, turn you car off. It is usually 1 of 2 things, the battery or the terminals are corroded, make sure you connecters are clean so a good metal to metal connection is made, on both termanals. if they where dirty or green or not on tight, give that a try, if that still does not work. Check your battery, take it to Checker or Autozone to test it, it is a free service...
If nothing I suggested worked, I am clueless at this point... Good Luck!!
Oct 13, 2006 at 7:52 PM
