1994 Pontiac Grand Prix Shaking at Speed
Does it seem to be more of a misfire or vibration?
The description of your symptom seems more of a wheel balance, or bent rim kind of problem.
If we do have a misfire going on, The very biggset concern on that motor is a leaking intake manifold. They are plastic and have a weak spot. Has your coolant level dropped at all?
OR
You can pull the exhaust down and wire it up, and see if that stops it.
Or if the O2 sensors aren't too bad in cost, replace them. I don't like to just throw parts at something, but sometimes that is the alternative your left with.
Or have a shop diagnosis it.
Glad you appreciate it. Some do, some don't...but thats people :)
How old are the ignition wires?
Suggested Repair
Cylinder 6 fuel injector was out of spec (about 10.8 ohms versus 11.8-12.6) and not delivering fuel, causing the shake, lean reading, and poor mileage. Professionally clean the injectors or replace injector 6; compression was acceptable and should not be below 100 psi. After replacement the car ran much better. For the remaining slight jerk near 45 mph, scan for codes and check ignition-wire age; prior misfire and oil use may also have affected the oxygen sensors or catalytic converter.
Conversation Summary
A 1994 Pontiac Grand Prix 3.1L shook badly above about 45 mph after plug wires had already fixed a rough idle. Mileage dropped, it burned oil, and a shop found cylinder 6 not firing, an out-of-spec injector, acceptable compression, old codes, a lean condition, and a sulfur smell. The expert advised cleaning or replacing that injector. After replacement the car ran nearly normally with much better mileage, leaving only an occasional initial jerk near 45 mph. The expert then recommended checking codes and ignition-wire age.
