First drain the fuel and put new fuel in, check the sparks and wires. Next clean all battery terminals and check the battery. Then change the oil, and put fresh in. Then disconect the coil and crank the engine to lube it up for about 10 seconds. Then hook up coil and try and start it if it runs great job, if not post back.
To check the headgasket, perform a compression test.
SPONSORED LINKS
Saturday, November 17th, 2007 AT 10:31 PM
