2002 Pontiac Grand Prix Hesitation
MORENKOM
I have a 2002 Pontiac Grand Prix (3.8 V6) with 94,000 miles and the original platinum spark plugs. Recently, it has started to hesitate when accellerating, especially from lower speeds. It even hesitates when the transmission shifts to a higher gear. It behaves like when the vacuum advance was bad on older engines. I don't think newer motors have vacuum advances, so I'm guessing it could be the plugs, injectors or catalytic converter.
Am I on the right track?
Aug 3, 2007 at 1:44 AM
CLY
  • 308 POSTS
A great place to start would be to go ahead and replace those plugs and take a close look at the plug wires while you have them off. Make sure and check the wires at the coils aswell. If it was a pluged converter it would lack power all the time and would not want to shift gears due to the engine load being so high.
Cly
Aug 3, 2007 at 7:41 AM
Suggested Repair
Replace the original spark plugs and inspect the plug wires, including the connections at the coils. A plugged catalytic converter is less likely because it would cause constant power loss and reluctance to shift.
Conversation Summary
The owner of a 2002 Pontiac Grand Prix 3.8 V6 with 94,000 miles reports hesitation during acceleration, especially from lower speeds and when the transmission upshifts. The original platinum spark plugs are still installed, and the owner suspects plugs, injectors, or the catalytic converter. The expert recommends replacing the plugs and closely inspecting the plug wires and coil connections, noting that a plugged converter would typically reduce power all the time and hinder shifting.
