I have had the several thermostats put in. I have plenty of anti-freeze in the system. I have had the heater core flushed and back flushed numerous times, a new water pump. They also flushed out the block twice. The hoses in and out of the heater core are both hot when car is at temp. The blower fan works fine on all speeds. I have had my cooling system bled twice. I am I going crazy?
Can this be an issue with my blend doors? Is my climate control sensor bad?
I notice that when the RPM's are above 1500-2000 the air does seem warmer, but any RPM below this and it is cool to cold air coming out.
There are no external leaks of anti-freeze, no leaking into the cabin of the car on the passenger side, also, there is no traces of anti-freeze in the oil or transmission fluid either, both are nice and clean. The operating temperature is normal, it is not over-heating at all and is operating within the normal range for this engine. 180 - 195 degres Fah.
I also noticed that everytime I start my car, the air conditioning bottom is lit up, idicating that it is on. I have to push the button off everytime I start the car. Could this indicate an issue with the cabin climate control?
It is a 3800 Series 3 supercharged V6, the GT model.
SPONSORED LINKS
Thursday, January 15th, 2009 AT 9:08 AM
