Okay, we are going to go down a bit of a backyard technique but it should flush out our offender.
Problems that only happen when hot take on a different kind of diagnosing. Getting it hot to the point of fialure, will give you time to lower the temperature of a part that is bad when hot.
You need to keep some cool water with you in a zip lock bad or similiar.( Some guys just pour the water). Three components that you need to cool off and restart the engine are the ignition Module, crank sensor or the
Computer. I would pour the water on the ignition module first then try to start it. If not go to the crank sensor. Lastly the computer. But I would keep water in the baggie and put it on to cool it. Or pull it and put it out side if it is cold out.
SPONSORED LINKS
Thursday, February 11th, 2010 AT 7:26 PM
