I need to drain and flush my 3.8 TODAY. I found what I think is the drain valve on drivers side. It is plastic and looks like it requires a special tool. I can barely get my hand to it and also need to know if it is left or right hand thread. What tool do I use to loosen and tighten. It has two plastic ears that could only be used to apply tourqe in 1 direction? HELP!
SPONSORED LINKS
Sunday, June 22nd, 2008 AT 12:58 PM
DOCFIXIT
MECHANIC
Turn counterclockwise
A long needlenose pliers may help.
The guy that designs never has to work on them.
Good luck
If no go on plug remove lower radiator hose
Sunday, June 22nd, 2008 AT 1:12 PM
SCOTT ARNOLD
MEMBER
Thank you very much. And yes. The design engineer"s don"t think about ease of repair for the guy at home! I am a tool maker and I run into this type of thing all the time!" CAN YOU DO THIS FOR ME. IT SHOULD ONLY TAKE A MINUTE" Yea. Right! Thanks again!
