2002 Pontiac Grand Prix loud roar when accelerating
153,000 MILES • 6 CYL • FWD • AUTOMATIC
JAYMAE44
Just a couple days ago i pushed in my parking break and it got stuck. I had a my sister husband take the wheel off and he knocked it loose and it was fine yesterday and earlier today. All of a sudden when I push the gas at all it doesn't start going as fast as it did before and there is a very loud noise almost as if I had the car in Neutral and i was reeving the engine. as soon as I let off the gas it stops. Also my car seemed to heat up faster than it normally does in the cold weather.
Feb 2, 2009 at 10:49 AM
CHOLLAR21
  • 5 POSTS
I would check out the catalytic converter. If this is clogged it could cause a loud noise and back pressure on the engine which could make the car run a little bit hotter. Also when it is clogged you will lose acceleration power. Hope this helps
[quote:f99fa01e29="jaymae44"]Noises problem
2002 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic 153000 miles
Just a couple days ago i pushed in my parking break and it got stuck. I had a my sister husband take the wheel off and he knocked it loose and it was fine yesterday and earlier today. All of a sudden when I push the gas at all it doesn't start going as fast as it did before and there is a very loud noise almost as if I had the car in Neutral and i was reeving the engine. as soon as I let off the gas it stops. Also my car seemed to heat up faster than it normally does in the cold weather.[/quote:f99fa01e29]
Feb 2, 2009 at 2:31 PM
