2001 Pontiac Grand Prix PROBLEM WITH AC OR HEATER STAYING O
2001 PONTIAC GRAND PRIX
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICARDO MIRANDA
OK THIS IS MY PROBLEM WHEN I START MY CAR SOMETIME THE AC COMES ON BUT ONLY ON HIGH AND SOMETIME NOT, I ALREADY CHANGED THE BLOWER RESISTOR THE AC CONTROL PANEL AND PUT IN A NEW BCM. WHEN I SHAKE THE IGNITON SWITCH THE FAN KICKS ON SOMETIMES,BUT WHEN I TRUN THE SWITCH FROM HIGH TO LOW IT BLOWS OUT THE AC AND MY IMFORMATION DISPLAY PANEL. WHERE DO I LOOK NEXT. COULD IT BE MY IGNITON SWITCH OR MAYBE A GROUND WIRE. WELL THANKS FOR YOUR HELP.
Aug 27, 2008 at 10:45 AM
2CARPRO JACK
  • 11,533 POSTS
If you can mess with the ignition switch and make it work, then I would start there.Im not real clear on what you mean "blows out the a/c and info panel" do you mean it comes out of the vents and not defrost?
Aug 28, 2008 at 12:50 AM
RICARDO MIRANDA
[quote:a41e871ec1="2CarPro Jack"]If you can mess with the ignition switch and make it work, then I would start there.Im not real clear on what you mean "blows out the a/c and info panel" do you mean it comes out of the vents and not defrost?[/quote:a41e871ec1] the a/c and or heat comes out in all the right places. i mean that the a/c and the display panel go out trun off when i put switch on low.
Aug 28, 2008 at 6:45 AM
2CARPRO JACK
  • 11,533 POSTS
Those are fed through the ignition switch, and if you can make them come on and turn off by messing with the ign switch, i would start there, if nothing else there is a problem with it if you can move it and make things go off and on
Aug 29, 2008 at 12:43 AM
