2001 Pontiac Grand Prix Noises/Stuck acceleration
2001 PONTIAC GRAND PRIX
90,000 MILES • 6 CYL • FWD • AUTOMATIC
BRITT90
Where do I start. There is a whirring noise which seems to be coming from the left side of the engine near the serpentine belt. My belt tensioner was changed a year ago, and seems to be on there securely. There is a faint tapping noise as well. Sometimes during acceleration the whirring noise becomes really intense and my car gets stuck in whichever gear it is in, reaching 6,000-7,000 RPMs before shifting.
Feb 14, 2010 at 1:40 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it may be a trans noise that is transmitting through the engine. Has it ever set a check engine light?if so start by having it scanned for codes, there may be a few in there that could lead to the root of the problem.
Feb 15, 2010 at 2:58 AM
BRITT90
Nope, no check engine light. My roomie checked the trans fluid, said it was low. He also had a premonition it was the power steering pump. Which makes no sense considering I got that changed less than a year ago. Needs some TLC anyways, gonna do some troubleshoot repairs. If I fail, back to the boards.
Thanks,
GTP Girl
Feb 15, 2010 at 8:23 AM
2CARPRO JACK
  • 11,533 POSTS
Try removing the belt and spinning all accesories by hand to see if you can feel a bad bearing or hear something out of the norm
Feb 15, 2010 at 11:57 AM
