2001 Pontiac Grand Prix Hasitation and pulling
CATHOMAS
  • 2001 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 98,000 MILES
Whenever I try to accelorate my car hesitates and then when I do get moving the car pulls me back like it's going to die but then dives normal and does it again. I've had the catalytic converter replaced on it but that hasn't fixed the problem.
Sunday, August 1st, 2010 AT 9:28 AM
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sunday, August 1st, 2010 AT 11:53 PM
