There's no way you should be replacing computers like that.
If the scanner couldn't access the computer, either the scanner was faulty, the OBD II port is damaged, or your wiring harness/connectors are broken, corroded or shorted. (Even a bad computer will show up on a scanner)
Instead of replacing the computer, take it out and have it tested. If it checks out, then it's probably your wiring harness.
Also, check you vehicle's ground. (Battery to engine/frame)
SPONSORED LINKS
Friday, January 22nd, 2010 AT 8:12 AM
