Heater problem
2000 Pontiac Grand Prix V6 Two Wheel Drive Automatic 182000 miles
there is no air at all coming out of the vents at all, no matter what the setting. What is the most likely problem
Sunday, December 2nd, 2007 AT 6:10 PM
BLACKOP555
MECHANIC
First check for voltage at the motor with the swithc on low and high if you have no voltage then you probbly have a faulty switch, if you have voltage then the blower motor is bad.
