2000 Pontiac Grand Prix fuel system
EL ROLANDO
  • 2000 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 180,000 MILES
Thanks for your time.
stall under heavy acceleration about 3/4 throttle. Replaced fuel filter. Should I replace pump? Also oil leak at valve covers. Any history on this problem?
Monday, May 11th, 2009 AT 12:09 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Monday, May 11th, 2009 AT 1:30 PM
