2000 Pontiac Grand Prix fuel system
120,000 MILES • 6 CYL • FWD • AUTOMATIC
FRTRUCKING
when the car starts it shuts off two seconds later what could be wrong
the car shuts off faster when you push on the gas
Jan 15, 2009 at 12:40 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:81a08669b4="frtrucking"]Engine Mechanical problem
2000 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic 120000 miles
when the car starts it shuts off two seconds later what could be wrong[/quote:81a08669b4]
Well, there could be several things that can cause your problem. So, Lets start with a few questions so I can give you a better diagnostic.
1) Is your check engine light on? If so we need to see about getting codes pulled.
2) When you start the vehicle can you press the gas peddle or pulse the gas peddle to keep it running?
It could be the TBS (Thottle Possition Sensor), MAP (Manifold Absolute Pressure Sensor), Fuel Pump or Fuel Pressure Regulator.
Jan 15, 2009 at 12:59 PM
