My supercharger belt ripped, I was wondering if its possible to repair this myself. On a rate 1 thru 10, 10 being best ill put myself as 5 at being handy with cars.
and if I can do it is there a diagram which shows which way/directions the belt goes?
SPONSORED LINKS
Monday, February 16th, 2009 AT 8:42 AM
BANDITGTP
MEMBER
When you look under your hood at the car frame, there should be a sticker that shows which way the belt should route around the pulleys. The only tool you will need is probably a socket wrench to realease the tension on the belt tensioner so that you can slip the belt into place.
