1997 Pontiac Grand Prix intermitten engine miss
SEVEN PINES
  • 1997 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 145,000 MILES
Sometimes engine will miss when accelerating
Tuesday, January 19th, 2010 AT 5:15 PM
Check and test the following below:
Oygen Sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Note:If it doesn't apply, disregard.
Tuesday, January 19th, 2010 AT 5:22 PM
