1997 Pontiac Grand Prix grinding noise
1997 PONTIAC GRAND PRIX
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHNANDEMILY09@YAHOO.COM
when i put it in gear and go it makes this really loud grinding noise,and when i gas on it its a little jumpy.i was thinking about buying it,it has been wrecked i don't know how bad.The guy at the car lot says it is the supercharger but i really doubt it.Do you have any idea what could be causing the noise?it almost sounds like i am dragging something behind me.
Feb 17, 2010 at 3:55 AM
MMPRINCE4000
  • CERTIFIED EXPERT
  • 8,548 POSTS
I would have car checked by a mechanic of your choice, if seller won't let you do that, RUN away.
The noise is most likely a CV shaft, or wheel bearing, I doubt it is supercharger, but if it is, it will have to be replaced, and blowers are not cheap.
The fact that it has been in a collision, makes it more important that you have it checked by a mechanic before you buy.
Feb 18, 2010 at 6:46 AM
