1997 Pontiac Grand Prix dash lights
GRANDPRIX
  • 1997 PONTIAC GRAND PRIX
Computer problem
1997 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
my brake light, park brake light & trac light stay on when car is started. Park brake works & car doesn't have brake fade. No codes are present.
what problem could I have?
thank you
Saturday, July 18th, 2009 AT 9:07 AM
MMPRINCE4000
  • 8,548 POSTS
Start by having the car scanned with a chassis scanner. A powertrain scanner will not display "C" (chassis codes).
If no "C" codes, it is most likely a MC low brake fluid switch
Sunday, July 19th, 2009 AT 8:24 AM
GRANDPRIX
  • 7 POSTS
I have leaky steel brake lines that need to be replaced.
Hence, the low fluid as you suggested.
Thank You.
Sunday, July 19th, 2009 AT 10:31 AM
MMPRINCE4000
  • 8,548 POSTS
When you fix the steel brake line, make sure to use a double inverted flare repair. DO NOT USE a compression fitting, they are not designed to withstand the hydraulic pressure generated by the brake system.
Thanks for using 2carpros. Mmprince4000
Monday, July 20th, 2009 AT 7:56 AM
GRANDPRIX
  • 7 POSTS
I picked up a dbl flare tool kit & a tubing bender today.
I parked the car til this weekend to do the job. I'll have help.
Thanks, again
Monday, July 20th, 2009 AT 4:21 PM
MMPRINCE4000
  • 8,548 POSTS
Good luck.
Tuesday, July 21st, 2009 AT 8:03 AM
