1995 Pontiac Grand Prix Starts with starter fluid then shut
220,000 MILES • 6 CYL • FWD • AUTOMATIC
LIFESPAN11
Its a 95 pontiac SE and it just died while i was driving it. We changed the crank positioning sensor, and fuel filter. But it still wont start. It will start with starter fluid but then shuts off when it burns it up. So im assuming that its not getting fuel some how cause it will run with the fluid. Someone suggested the fuel pressure might be low. And the fuel pump turns on when you turn the key. Any help or advice would be appreciated. Thank you.
Apr 30, 2008 at 1:12 PM
LEGITIMATE007
  • 5,121 POSTS
yes you from what your telling me it sounds like you have low pressure. I'm gonna give you a link thoshow you how to check it easily yourself.
Apr 30, 2008 at 1:20 PM
LEGITIMATE007
  • 5,121 POSTS
here you go this is a video link that will show you how to check for fuel pressure. very good video
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Apr 30, 2008 at 1:22 PM
