1994 Pontiac Grand Prix Hood release
1994 PONTIAC GRAND PRIX
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIM94
This is my daughters car, and I'm just trying to help her out. First the inside hood release broke. Her temp has been running around 190' but heater doesn't always blow hot air. I't not low on coolant. Doesn't have any coolant in the oil, but I do suspect head gasket problems. I don't know much about Pontiacs any help would be appreciated.
Tim
Feb 18, 2008 at 11:18 PM
2CARPRO JACK
  • 11,533 POSTS
Can you get the hood open? try from underneath the front if not. Temp sounds about right, might have a partially plugged heater core. Have it chemical tested for a blown head gasket to rule that out first, if ok have the cooling system flushed
Feb 18, 2008 at 11:29 PM
