1993 Pontiac Grand Prix Cooling Fans
MAXISKY
  • 1993 PONTIAC GRAND PRIX
Engine Cooling problem
1993 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
I just bought the car and brought it home today and noticed the cooling fans never kicked on. What could be causing this?
Tuesday, September 14th, 2010 AT 7:32 PM
WRENCHTECH
  • 20,761 POSTS
Have you tried the A/C to see if they run with the A/C. They aren't supposed to come on for temp until after 225degrees.
Tuesday, September 14th, 2010 AT 7:40 PM
MAXISKY
  • 8 POSTS
[quote="Wrenchtech"]Have you tried the A/C to see if they run with the A/C. [Quote]
No just checked it and the cooling fans didn't come on with the a/c.
Thursday, September 16th, 2010 AT 2:26 PM
WRENCHTECH
  • 20,761 POSTS
Try running power and ground directly from the battery to the fan motor to test it.
Thursday, September 16th, 2010 AT 2:30 PM
MAXISKY
  • 8 POSTS
Yes hooking it upo directly to the batter both fans work.
Friday, September 17th, 2010 AT 9:30 AM
WRENCHTECH
  • 20,761 POSTS
There are 2 fusible links that have to be checked, probably located at the starter. Then check fuse the IGN fuse (15amp).
Friday, September 17th, 2010 AT 9:35 AM
MAXISKY
  • 8 POSTS
I looked and could not find any inline fuses from the starter and the ing fuse 15 amp is good. So possibly could it be the relays on the fender wall?
Saturday, September 18th, 2010 AT 4:49 PM
WRENCHTECH
  • 20,761 POSTS
Your not looking for inline fuses. Your looking for fusible links which are meltaway wires and they are attached to the main terminal of the starter. Pull on each one and if any stretch, they are burn inside. Use only fuse wire to repair it.
Saturday, September 18th, 2010 AT 4:52 PM
MAXISKY
  • 8 POSTS
Fusable links look goos do not stretch when pulled.
Saturday, September 18th, 2010 AT 5:14 PM
WRENCHTECH
  • 20,761 POSTS
I've given you all the easy things to check. This is where someone has to start following a wiring diagram and testing the circuit to determine where things are being lost. Your going to need some help and test equipment from here.
Saturday, September 18th, 2010 AT 5:20 PM
MAXISKY
  • 8 POSTS
I thank you very much for your time and experiance.
Saturday, September 18th, 2010 AT 5:29 PM
MAXISKY
  • 8 POSTS
What would cause the a/c to quit and the car not to start also the radio ndoesn't work and the warning lights stay on even with the key off and out of the ignition.
Wednesday, September 22nd, 2010 AT 5:19 PM
WRENCHTECH
  • 20,761 POSTS
You need to start a whole new question for that stuff.
Wednesday, September 22nd, 2010 AT 5:32 PM
